Console BIOS Settings
If you require assistance with identifying your consoles motherboard or need further help, please send an email to support@avolites.com. When sending technical queries please include Serial Number & Software Versions where appropriate as this may speed up diagnoses of problems.
If your console has been upgraded, a sticker will have been applied to the back labelled 'V2 Hardware' or 'V3 Hardware'. If you are unable to find this then you can identify your motherboard by the following:
LV-677: 1 x Ethernet Port, 2 x USB Ports
LV-67H: 2 x Ethernet Ports, 4 x USB Ports
Fujitsu V2 Hardware: 2 x Ethernet Ports, 8 x USB Ports (Incl. 2 x USB 3.0 Blue)
Fujitsu V3 Hardware: 2 x Ethernet Ports, 8 x USB Ports (Incl. 2 x USB 3.1 Red)
You can go directly to the BIOS Setup Utility by pressing the [F2] or [DEL] key on the keyboard during start up. When prompted, type in the password “68340”.
Titan Net Processor (LV-67H) || TNP-00001 - TNP-00100
BIOS settings as below (based on default loaded)
Under the Exit menu, select “Load Optimised Defaults” and press enter
Under the Security menu, set both the “Supervisor Password” and “User Password” to 68340
Enter the “Main” Menu, and set the correct “Date and Time
In  “Main”, enter “Boot features”, and set the NumLock to “Off
In “Advanced” enter “System Agent (SA) Configuration” then select  “Graphics Configuration” and Finally select “IGD Configuration” and set as follows:
IGD - Boot Type to LVDS
IGD – Secondary Boot Type to DVI
IGD – LCD Panel Type to Reserved #13 LVDS Color Panel
Panel Color Depth to 18 Bit
Enter the “Advanced” menu, and then enter the “South Bridge Configuration” menu
Enter the “SB PCI Express Config” menu
Enter the “PCI Express Port 1” menu, and change the “ASPM” setting to “Disabled
Go back to the “SB PCI Express Config” menu
Enter the “PCI Express Port 2” menu, and change the “ASPM” setting to “Disabled
Enter the “Boot” Menu to change the hard disk Boot Priority Order as follows:
Set the [USB HDD] to 1
Set the [USB CD] to 2
Set the [ATA HDD0] to 3
Disable the other devices by selecting them and pressing Shift + 1
Enter the “Others” Menu, and then enter the “SIO Configuration” Menu
Set the “Powerloss / Powercontrol” setting to [Always Off]
Go to the Exit menu. Select “Exit Saving Changes”, press Enter, then Y, then Enter
Titan Net Processor (Fujitsu V2 Hardware) || TNP-00101 - TNP-00215
Under the “Save & Exit ” menu, select “Restore Defaults” and press enter
Enter the “Main” Menu, and set the correct “System Date and System Time”
In “Advanced” enter “USB Configuration” then select “xHCI Mode” and set it as “Disabled”
In “Advanced” enter “LVDS Configuration” then select “LVDS support” and set it as “Enabled” then set as follows:
Non–EDID Support                         Enabled
LVDS Panel Config Select              LVDS adjusted Parameters
LVDS Mode                                     LDI 8-Bit
LVDS Brightness                             255
Under the “Security” menu, set “Administrator Password” to 68340
In “Power” menu set as follows:
Power Failure Recovery                    Disabled
Never Off                                           Disabled (default)
Hibernate like Soft Off                       Disabled
USB at Power-Off                              Always Off (default)
In “Wake Up Resources” set “LAN” as “Disabled
Set “Bootup NumLock State” to “Off
Set “Prefer USB Boot” to “Enabled
Change the hard disk Boot Option Priority as follows: Boot Option #1 to or Boot Option #2 to [Diagnostic Program]
Go to the “Save & Exit” menu. Select “Save Changes and Exit”, press Enter
Titan Net Processor (Fujitsu V3 Hardware) || TNP-00216 - Onwards
Under the “Save & Exit” menu, select “Restore Defaults” and press enter
Under the “Main” menu  Select System Information and check:
BIOS Revision:                         R1.3.0 or Above
Build Date and Time:               10/12/2018 10:56:25
Set the correct “System Date and System Time
Under “Advanced” menu Enter “CPU Configuration” then select “C States” and set it as “Disabled” (default)
NOTE: Usually the C States is set as Disabled by default but it needs to be checked
Under “Advanced” Enter “LVDS Configuration” then select “LVDS support” and set it as “Enabled” then set as follows:
LVDS Mode                                     LDI 8-Bit
LVDS Brightness                             14
Under the “Security” menu Set “Supervisor Password” to 68340
Under “Power” menu set as follows:
USB/PS2 Power                                Always Off (default)
Under “Boot” menu  Set “Bootup NumLock State” to “Off
Go to the “Save & Exit” menu Select “Save Changes and Reset”, press Enter
Quartz
Press F9 and Y followed by Enter
Press F10 and Y followed by Enter
Tiger Touch (LV-677) || TT-00001 - TT-01212
Select “Load Optimized Defaults” and enter
Set “User Password” to 68340
Enter the “Standard CMOS Features” Menu
Set the correct “Date and Time
Set “Drive A” to [none]
Set “Halt on” to [All, But Keyboard]
Enter the “Advanced BIOS Features” Menu
Set the “First Boot Device” to [Hard Disk]
Set the “Second Boot Device” to [Disabled]
Set the “Third Boot Device” to [Disabled]
Set “Swap Floppy Drive” to [Disabled]
Set “Boot Up Floppy Seek” to [Disabled]
Set “Boot Up NumLock Status” to [Off]
Enter the “Advanced Chipset Settings” Menu
Set the “Onchip VGA Control” to [Auto]
Set the “LCD Type” to [7]
Enter the “Integrated Peripherals” Menu, and then enter the “Onboard Device” Menu
Set the “USB Keyboard Support” to [Enabled]
Enter the “Integrated Peripheral” Menu, and then enter the “Super IO Device” Menu
Set the “PWRON After PWR-Fail” to [Former-Sts], Press Escape, then F10 to Save to CMOS and Y followed by Enter
Tiger Touch Pro (LV-67H) || TT-01220 - TT-01615
Under the Exit menu, select “Load Optimized Defaults” and press enter
In “Advanced” enter “System Agent (SA) Configuration” then select  “ Graphics Configuration” and Finally select “IGD Configuration” and set as follows:
IGD – Boot Type to LVDS
IGD – Secondary Boot Type to CRT
IGD – LCD Panel Type to 1280 x 800 LVDS Color Panel
Tiger Touch Pro (Fujitsu V2 Hardware)
BIOS Revision:                           R1.26.0.SR.2
Build Date and Time:                  09/08/2015 12:03:30
Under “Advanced” menu, Enter “USB Configuration” then select “xHCI Mode” and set it as “Disabled
Under “Advanced”, Enter “LVDS Configuration” then select “LVDS support” and set it as “Enabled” then set as follows:
LVDS Panel Config                            1280 x 800
LVDS Mode                                        LDI 6-Bit
LVDS Brightness                                255
Under “Boot” Menu, set “Bootup NumLock State” to “Off
Go to the “Save & Exit” menu Select “Save Changes and Exit”, press Enter
Tiger Touch Pro (Fujitsu V3 Hardware)
Under “Advanced” Enter “LVDS Configuration” then select “LVDS support” and set it as “Enabled”, then set as follows:
LVDS Panel Config Select              1280 x 800
LVDS Mode                                     LDI 6-Bit
LVDS Brightness                             8
Tiger Touch II (LV-67H) || TT-02006 - TT-03065
in  “Main”, enter “Boot features”, and set the NumLock to “Off
IGD – LCD Panel Type to 1366 x 768 LVDS Co
Panel Color Depth to 24 Bit
Go back to the “SB PCI Express Config” menu,  enter the “PCI Express Port 2” menu, and change the “ASPM” setting to “Disabled
Tiger Touch II (Fujistu V2 Hardware) || TT-03066 - TT-04020
LVDS Panel Config                     1366 x 768
LVDS Mode                                 FPDI 8-Bit (default)
LVDS Brightness                         255
Enter the “Boot” Menu, set “Bootup NumLock State” to “Off
Tiger Touch II (Fujitsu V3 Hardware) || TT-04021 - Onwards
LVDS Panel Config Select                   1366 x 768
LVDS Brightness                                  8
Pearl Expert (LV-677) || PEXP-00001 - PEXP-01944
Set the “Boot Other Device” to [Disabled]
Set the “Boot Display” to [CRT]
Pearl Expert Pro (LV-67H) || PEXP-01945 - Onwards
Panel Color Depth to 18 Bit.
Enter the “SB PCI Express Config” menu, enter the “PCI Express Port 1” menu, and change the “ASPM” setting to “Disabled
Go back to the “SB PCI Express Config” menu and enter the “PCI Express Port 2” menu, and change the “ASPM” setting to “Disabled
Pearl Expert Pro (Fujitsu V2 Hardware)
Under the “Main” menu, select System Information and check:
LVDS Mode                                LDI 6-Bit
LVDS Brightness                         255
Go to the “Save & Exit” menu, select “Save Changes and Exit”, press Enter
Pearl Expert Pro (Fujitsu V3 Hardware)
LVDS Mode                                          LDI 6-Bit
LVDS Brightness                                  8
Arena (Fujitsu V2 Hardware) || AR-00001 - AR-00783
LVDS Brightness                        255
Enter the “Boot” Menu and set “Bootup NumLock State” to “Off
Arena (Fujitsu V3 Hardware) || AR-00784 - Onwards
LVDS Brightness                             8
Sapphire Touch (LV-67H) || ST-00001 - ST-00299
BIOS settings as below(based on default loaded)
Set the [ATA HDD3] to 3
Under Main Menu / Boot Features, set “NumLock Status” to [Off]
Sapphire Touch (Fujitsu V2 Hardware) || ST-00300 - ST-00410
Sapphire Touch (Fujitsu V3 Hardware) || ST-00411 - Onwards
