Titan Troubleshooting
If you can't find a solution to your issue, please send an email to our Service Manager. When sending technical queries please include Serial Number & Software versions where appropriate as this may speed up diagnoses of problems.
FAQ 10035 - Titan Remote Android Connection Issues
FAQ 10034 - Tiger Touch DMX Card Firmware Update
These instructions relate to updating the DMX card firmware for Tiger Touch and Tiger Touch Pro consoles. The update is only required on these two product types and should not be performed on any other products. The update is to resolve an issue where the DMX stops outputting randomly after around 6 hours use of the console.
Please download the update using the following link.
DMX Firmware Update V6.1.23
Once you have inserted the USB stick please follow these steps.
1)      Shutdown the software from the Tools menu
2)      Open Explorer from the Tools menu
3)      Browse to the file UsbExpertSetupV6.2(23).msi
4)      Run the setup and follow the instructions carefully.
5)      Once the setup has completed it should prompt you to restart the console.
6)      After the console restarts it should prompt you in Health Check to update the firmware.
7)      Select Fix or open USB Expert from the Tools menu
8)      Select the Tab labelled “Service”
9)      Select “Auto Update”
10)   The update process should happen automatically and will take about 10min..
To verify that the firmware has updated successfully you can select the Dmx Panel (int USB Expert) and in the Info tab it should display the SoftwareVersion. This should read "Nov 6 2014".
FAQ 10033 - An error has been detected which is preventing start up.
FAQ 10031 - Titan One and Titan Mobile Fixing Dongle Not Found after Software Update
FAQ 10030 - How can I update my panel firmware?
FAQ 10029 - How can I test and replace the battery on my Avolites Borris motherboard?
FAQ 10028 - How can I format a 720k floppy disk for my antique console?
FAQ 10027 - How can I use theatre stack mode on a Tiger?
FAQ 10026 - Why has my DMX stopped?
FAQ 10025 - What PSU do I need?
FAQ 10024 - How and when do I use my Pearl Expert recovery disk?
FAQ 10023 - How do I load a show from a floppy disk on a Pearl Tiger?
FAQ 10022 - How do I move a show file from a USB stick to a floppy disk, so I can load into a Pearl 2004?
FAQ 10021 - How do I move several shows from floppy disks to a single USB pen?
FAQ 10020 - How do I move a show file from floppy disk to USB stick on a PC?
FAQ 10019 - My Rack Splitter is not working?
FAQ 10018 - My Truss Splitter is not working?
FAQ 10017 - How do I make a Visualiser MIDI cable?
FAQ 10016 - Can I run two or more chases simultaneously on the same fixture?
FAQ 10015 - How do I get new personality files programmed?
FAQ 10014 - My Program Panel occasionally looses power?
FAQ 10013 - What does the Avolites Button do?
FAQ 10012 - What is AVOS?
FAQ 10010 - Noisy Mains!
FAQ 10009 - Memory Related Problems
FAQ 10008 - VGA Related Problems!
FAQ 10007 - My floppy disk drive does not work?
On older desks, a modification to the disk drive may be necessary. This involves linking two pins on the disk drive as shown below.
If this link is NOT made some functions on the DISK MENU will not work :-
  • The "Format & Save" option will not function.
    However, the "Format" and the "Save" options will still function if they are executed separately.
Floppy links
Q. Will any computer floppy disk drive work on my desk?
A. The answer is yes, as long as you are using the latest software and AVOS.
Q. Why does the light on the floppy drive stay on when it's not being used?
A. On the latest version of the software the modification on the floppy drive is not required. If you want the light to turn off remove the modification in the drive.
Floppy Disk Drive (FDD) Repair & Maintenance
A regularly maintained FDD's will rarely cause any problems. The majority of problems that do occur on a FDD can be fixed easily.
What can go wrong with a FDD?
Problem
The most common problem occurs when the 34 way ribbon cable is removed from the FDD.
If this cable (connects the FDD to the Borris motherboard) is then plugged in backwards on the floppy drive, the drive will NOT work and the floppy drive LED light may stay on permanently.
Solution
Remove the cable from the back of the FDD and re-insert it correctly.
floppy disk drive
Problem
Spindle Motor or Electrical Circuit Burn Out - With age, the spindle motor and electrical circuits can burn out, but this doesn't happen very often. The most common cause for this is a dirty/dusty FDD.
Solution
Vacuuming in and around the FDD (when cleaning the console) will help to extend the life of your FDD.
Problem
FDD Read/Write Errors  - The read/write heads in the FDD can and do become dirty with time. Environmental conditions will add to this problem (dusty or smoky areas!).
Solution
Regular cleaning of the read/write heads with a commercially available FDD HEAD CLEANER.
These look just like a floppy disk on the outside, but inside the case is a special pad on which you put a couple of drops of a special cleaner fluid that comes with the kit. Always use the drops, as a dry pad can scratch the heads.
Additionally, replace the cleaner-disk as recommended on the package, or when the disk pad appears dirty.
Note that a dirty cleaner-disk can also scratch the heads.
Problem
FDD Read/Write Errors - Head Alignment
With age, the read/write heads can become moved out of alignment.
At first, you will notice that you can read/write to your floppy disk, but the disk can not be read on another consoles' FDD.
Eventually, the FDD will not read/write at all.
Solution
Replace the FDD.
Although the heads can be re-aligned with special equipment, the cost would outweigh the price of a inexpensive new FDD.
FAQ 10006 - I appear to have DMX related problems!
FAQ 10005 - My Graphics Tablet is malfunctioning?
1212 HR II Graphics Tablet.
1212 HR II Graphics Tablet - the old type.
On the 1212 HR II Graphic Tablet are three status LED's - these indicate the condition of the Tablet.
Power LED is lit when power is ON
Sense LED is lit when the stylus is in the working area and within the proximity
Status LED "Lights" when a button on the stylus is pressed
1212 HR III Graphics Tablet.
1212 HR III Graphics Tablet - the new type.
On the 1212 HR III Graphic Tablet are three status LED's - these indicate the condition of the Tablet.
Power LED flashes when the tablet has power but the pen is not within the working area.
Status LED is lit when the stylus is in the working area and within the proximity
Mode LED "Lights" when a button on the stylus is pressed
Troubleshooting
Before you confirm your tablet does not function properly and decide to send it back to AVOLITES for repair, please go through the following steps:
  • If the Power LED flashes when the stylus is in the working area, then it's very possible that the graphic tablet does not work properly
  • When the Power LED is on and the LED does not flash when the stylus is on the working area, then check and make sure all the connections are secure. If the breakdown is due to disconnection, switch off the desk and connect all the cables firmly and then restart the desk and the graphics tablet.
  • If for any reason the stylus has been unplugged while the graphics tablet is on, we strongly suggest that you press the key "RESET" in order to make it function properly.
Care & Cleaning
As with all electrical equipment, it is necessary to exercise care while handling and cleaning the graphic tablet. Please note the following :-
  • Avoid dropping or knocking the tablet or stylus.
  • To clean the tablet and its accessories, make sure the desk and graphics tablet is switched off.
  • Use a soft cloth lightly damped with water or a non-abrasive cleaner which does not harm plastic components.
  • Do not use chemicals or abrasive materials which may damage the surface.
  • Never immerse any part of the tablet or stylus in any liquid, as this will damage the circuitry inside.
FAQ 10004 - My keyboard does not work?
The QWERTY DIN socket is for connecting a standard PC keyboard.
This is used for entering legends to name memories, chases and palettes.
Before you confirm that your keyboard does not function properly, please note that you should always connect the keyboard to the desk before powering up the desk.
Note that for newer style keyboards, a PS/2 Style Keyboard Adaptor Cable is required - contact Avolites for further details.
FAQ 10003 - How do I link out the Grand Master Fader on a Pearl?
FAQ 10002 - How do I set the Program links?
FAQ 10001 - How do I perform a hardware WIPEALL?
FAQ 10001
  1. Firstly, save any show data in the console onto a floppy disk.
    This is very important as any data in the console will be lost.
    You have been warned!!!
  2. Switch the console off
  3. Lift up the top panel on the console after undoing the screws.
  4. Locate the WipeAll link on the Borris motherboard (see photos below).
  5. Fit a jumper across the two pins and turn the console on.
  6. Wait until the console has properly initialised (about 10 seconds max) and then switch OFF the console.
  7. Replace the jumper onto one leg of the link, close the lid and tighten the screws by turning one-quarter turn clockwise.
  8. Power ON the desk and reload your show from your backup disks.
There is now an alternative method of performing a WIPEALL without having to open up the console. To do this you must be running the latest software on your console.
Click here to go to our Download site to check what the latest version for your console is.
This feature is available on Azure, Pearl and Sapphire consoles but is NOT yet implemented on the Diamond II and III's.
  1. Press and hold preset ADD buttons 21 and 30, then switch ON the desk. (Playback buttons 21 and 30 on the Azure)
  2. The desk will enter the AVOS menu (AVOS date must be June 2000 or later)
  3. Press 1 then hit ENTER to start and execute a wipeall.
Tiger Touch Non Pro BIOS Settings (LV677 Motherboard)
Tiger Touch Non Pro
Select “Load Optimized Defaults” and enter
Set “Supervisor Password” to 68340
Set “User Password” to 68340
Enter the “Standard CMOS Features” Menu
Set the correct “Date and Time
Set “Drive A” to [none]
Set “Halt on” to [All, But Keyboard]
Enter the “Advanced BIOS Features” Menu
Set the “First Boot Device” to [Hard Disk]
Set the “Second Boot Device” to [Disabled]
Set the “Third Boot Device” to [Disabled]
Set “Swap Floppy Drive” to [Disabled]
Set “Boot Up Floppy Seek” to [Disabled]
Set “Boot Up NumLock Status” to [Off]
Enter the “
Advanced Chipset Settings” Menu
Set the “
Onchip VGA Control” to [Auto]
Set the “LCD Type” to [7]
Enter the
Integrated Peripherals” Menu, and
then enter the “Onboard Device” Menu.
Set the “USB Keyboard Support” to [Enabled]
Enter the “Integrated Peripheral” Menu, and
then enter the “Super IO Device” Menu.
Set the “PWRON After PWR-Fail” to [Former-Sts]
Press Escape, then F10 to Save to CMOS and Y followed by Enter
Pearl Expert Non Pro BIOS Settings (LV677 Motherboard)
Set the “Boot Other Device” to [Disabled]
Enter the “Advanced Chipset Settings” Menu
Set the “Onchip VGA Control” to [Auto]
Set the “Boot Display” to CRT}
Enter the “Integrated Peripherals” Menu, and
Titan Net Processor BIOS Settings (LV67 - H Motherboard)
BIOS settings as below (based on default loaded)
Under the Exit menu, select “Load Optimised Defaults” and press enter
Under the Security menu, set both the “Supervisor Password” and “User Password” to 68340
Enter the “Main” Menu, and set the correct “Date and Time
in  “Main”, enter “Boot features”, and set the NumLock to “Off
In “Advanced” enter “System Agent (SA) Configuration” then select  “ Graphics Configuration” and Finally select “IGD Configuration” and set as follows:
IGD – Boot Type to LVDS
IGD – Secondary Boot Type to DVI
IGD – LCD Panel Type to Reserved #13 LVDS Color Panel
Panel Color Depth to 18 Bit.
Enter the “Advanced” menu, and then enter the “South Bridge Configuration” menu.
Enter the “SB PCI Express Config” menu.
Enter the “PCI Express Port 1” menu, and change the “ASPM” setting to “Disabled”.
Go back to the “SB PCI Express Config” menu.
Enter the “PCI Express Port 2” menu, and change the “ASPM” setting to “Disabled”.
Enter the “Boot” Menu to change the hard disk Boot Priority Order as follows:
Set the [USB HDD] to 1
Set the [USB CD] to 2
Set the [ATA HDD0] to 3
Disable the other devices by selecting them and pressing Shift + 1
Enter the “Others” Menu, and then enter the “SIO Configuration” Menu.
Set the “Powerloss / Powercontrol” setting to [Always Off]
Go to the Exit menu. Select “Exit Saving Changes”, press Enter, then Y, then Enter.
Tiger Touch Pro BIOS Settings (LV67-H Motherboard)
Tiger Touch Pro
Under the Exit menu, select “Load Optimized Defaults” and press enter
in  Main”, enter “Boot features”, and set the NumLock to “Off
In “Advanced” enter “System Agent (SA) Configuration” then select  Graphics Configuration” and Finally select “IGD Configuration” and set as follows:
IGD – Secondary Boot Type to CRT
IGD – LCD Panel Type to 1280 x 800 LVDS Color Panel
Tiger Touch II BIOS Settings (LV67-H Motherboard)
Tiger Touch II
IGD – LCD Panel Type to 1366 x 768 LVDS Co
Panel Color Depth to 24 Bit.
Pearl Expert Pro BIOS Settings (LV67-H Motherboard)
Pearl Expert Pro
  • Under the Exit menu, select “Load Optimized Defaults” and press enter
  • In “Advanced” enter “System Agent (SA) Configuration” then select  Graphics Configuration” and Finally select “IGD Configuration” and set as follows:
  • Enter the “Advanced” menu, and then enter the “South Bridge Configuration” menu.
  • Enter the “SB PCI Express Config” menu.
  • Enter the “PCI Express Port 1” menu, and change the “ASPM” setting to “Disabled”.
  • Go back to the “SB PCI Express Config” menu.
  • Enter the “PCI Express Port 2” menu, and change the “ASPM” setting to “Disabled”.
  • Enter the “Boot” Menu to change the hard disk Boot Priority Order as follows:
  • Disable the other devices by selecting them and pressing Shift + 1
  • Enter the “Others” Menu, and then enter the “SIO Configuration” Menu.
  • Go to the Exit menu. Select “Exit Saving Changes”, press Enter, then Y, then Enter.
Sapphire Touch BIOS Settings (LV67-H Motherboard)
Sapphire Touch
BIOS settings as below(based on default loaded)
Set the [ATA HDD3] to 3
Under Main Menu / Boot Features, set “NumLock Status” to [Off]
Titan Net Processor BIOS Settings (Fujitsu V2 Hardware Motherboard)
Under the “Save & Exit” menu, select “Restore Defaults” and press enter
Enter the “Main” Menu, and set the correct “System Date and System Time”
In “Advanced” enter “USB Configuration” then select “xHCI Mode” and set it as “Disabled”
In “Advanced” enter “LVDS Configuration” then select “LVDS support” and set it as “Enabled” then set as
follows:
Non–EDID Support Enabled LVDS Panel Config Select LVDS adjusted Parameters LVDS Mode LDI 8-
Bit
LVDS Brightness 255
Under the “Security” menu, set “Administrator Password” to 68340
In “Power” menu set as follows:
Power Failure Recovery Disabled
Never Off Disabled (default)
Hibernate like Soft Off Disabled
USB at Power-Off Always Off (default)
In “Wake Up Resources” set “LAN” as “Disabled”
Set “Bootup NumLock State” to “Off”
Set “Prefer USB Boot” to “Enabled”
Change the hard disk Boot Option Priority as follows: Boot Option #1 to or
Boot Option #2 to [Diagnostic Program]
Go to the “Save & Exit” menu. Select “Save Changes and Exit”, press Enter.
Tiger Touch Pro and Pearl Expert Consoles BIOS Settings (Fujitsu V2 Hardware Motherboard)
Under the “Main” menu
Select System Information and check:
- BIOS Revision: R1.26.0.SR.2
- Build Date and Time: 09/08/2015 12:03:30
Set the correct “System Date and System Time”
Under “Advanced” menu
Enter “USB Configuration” then select “xHCI Mode” and set it as “Disabled”
Under “Advanced”
Enter “LVDS Configuration” then select “LVDS support” and set it as “Enabled” then set as follows:
Non–EDID Support Enabled LVDS Panel Config Select 1280 x 800 LVDS Mode LDI 6-Bit
LVDS Brightness 255
Set “Administrator Password” to 68340
Under “Power” menu set as follows:
Under “Boot” Menu
Tiger Touch II Console BIOS Settings (Fujitsu V2 Hardware Motherboard)
follows:
Non–EDID Support Enabled LVDS Panel Config Select 1366 x 768 LVDS Mode FPDI 8-Bit (default)
LVDS Brightness 255
Arena Console BIOS Settings (Fujitsu V2 Hardware Motherboard)
follows:
LVDS Brightness 255
Sapphire Touch BIOS Settings (Fujitsu V2 Hardware Motherboard)
Titan Net Processor BIOS Settings (Fujitsu V3 Hardware Motherboard)
Under the “Main” menu  Select System Information and check:
BIOS Revision:          R1.3.0 or Above
Build Date and Time: 10/12/2018 10:56:25
Under “Advanced” menu Enter “CPU Configuration” then select “C States” and set it as “Disabled” (default)
NOTE: Usually the C States is set as Disabled by default but it needs to be checked
Under “Advanced” Enter “LVDS Configuration” then select “LVDS support” and set it as “Enabled”
LVDS Mode                                       LDI 8-Bit
LVDS Brightness                            14
Under the “Security” menu Set “Supervisor Password” to 68340
USB/PS2 Power                           Always Off (default)
Under “Boot” menu  Set “Bootup NumLock State” to “Off”
Go to the “Save & Exit” menu Select “Save Changes and Reset”, press Enter
Tiger Touch Pro and Pearl Expert Consoles BIOS Settings (Fujitsu V3 Hardware Motherboard)
- Build Date and Time: 10/12/2018 10:56:25
LVDS Mode                                       LDI 6-Bit
LVDS Brightness                            8
Tiger Touch II Console BIOS Settings (Fujitsu V3 Hardware Motherboard)
- BIOS Revision:          R1.3.0 or Above
LVDS Brightness                              8
Arena Console BIOS Settings (Fujitsu V3 Hardware Motherboard)
BIOS settings as below (based on default loaded)Under the “Save & Exit” menu, select “Restore Defaults” and press enter
- BIOS Revision:          R1.3.0 or Above- Build Date and Time: 10/12/2018 10:56:25
LVDS Brightness                              8
Power Failure Recovery         DisabledNever Off                                         Disabled (default)
Sapphire Touch BIOS Settings (Fujitsu V3 Hardware Motherboard)
DMX Driver Chip Replacement
The following consoles will contain an additional pair of DMX driver chips that are located on the ST-DMX Board (below the MIDI-IN port):
Tiger Touch II, Arena, Sapphire Touch and Titan Net Processor
 When replacing the driver chip, you will need to make sure the chip is inserted correctly.
Please note: a DMX driver chip is also included in the spare parts kit for the following consoles:
Quartz, Tiger Touch II and Arena
I
If you require additional driver chips, they can be ordered via your local Avolites Distributor.
Titan Mobile, Quartz, Tiger Touch II, Arena, Sapphire Touch
Part Number #05-03-0970
Tiger Touch/Pro, Pearl Expert/Pro
Part Number #05-03-0433
The touch screen on my console is not behaving as expected. How do I fix this?
 If you are experiencing unusual touch screen behaviour (e.g. mouse going haywire), then the screen will need to be cleaned thoroughly. This includes the corner edges of the screen.
To clean the corner edges of the screen, you will need to use either a brush or a business card.  Once you have cleaned the screen, apply a touch screen and sensitivity calibration.
.NET 4.7.2 Compatibility error during install
Titan Version 12 requires .NET 4.7.2 to run. If you have received the “.NET Compatibility” error during install this probably means your windows version is out of date. You might need to perform windows updates on windows 10 to get to one of these versions.
Supported versions are:
Windows 10 Anniversary Update and later (version 1607 and later) (x86 and x64)
Windows 8.1 (x86 and x64)
Windows 7 Service Pack 1 (x86 and x64)
Downgrading from V12 to V11 - Unsupported DMX Firmware
Please note that using upgrade installers for older versions of Titan after running the V12 recovery is not currently supported and will prevent the console from starting if attempted. If you need to downgrade to a previous version it is important that this is done via a relevant recovery stick only. Consoles not starting following an attempt to use an earlier upgrade installer can be fixed by running a recovery stick and selecting Full Erase option (if recovering to a version prior to V12, you can reuse the license which was emailed to you previously).
When downgrading from V12 to previous versions of Titan it is also important that the Sapphire DMX panel firmware is downgraded in any consoles with ST-DMX cards (Sapphire Touch, TitanNet Processor, Tiger Touch II and Arena). This is because new features in the firmware are not compatible with previous versions. To downgrade the firmware open USB Expert Console and put any Sapphire DMX Panels into Boot Mode. This is found in the Service Tab. When the panels have re-appeared in boot mode, select Program which will open a file dialog. In the file dialog navigate to C:\Program Files (x86)\Avolites\UsbExpert\Panel Software and select the st_dmx.bin file. This will now install the previous ST-DMX firmware. Once this is complete do the same on all Sapphire DMX panels and then exit Boot mode. Now restart the console and you should now be OK to use the previous version of Titan. When you next upgrade to V12 you will need to carry out the firmware update again.
Intel Command Center Service Prevents Titan from starting
 Intel has issued a driver update for their built in graphics cards that may cause issues with Titan starting up.
If you try and launch a PC suite application ( Simulator, TitanOne, TitanGo, and Mobile) and it does not complete start up and stays on the “pulsing grey Titan screen”. Also check in the Task Manager for windows if you see the “oneapp.igcc.winservice”, and or “Intel® Graphics Command Center Service” You will need to perform the following fix to
allow Titan to run again.
This driver update may come thru a windows update or by installing the Intel drivers manually. The drivers lock up ports required by Titan to run correctly.
After confirming in the Task Manger of  Windows (control- alt - delete on keyboard then select task manager from the pop up list) that the “oneapp.igcc.winservice”, and or “Intel® Graphics Command Center Service” are running do the following:
  • In Task Manger click the Services
  • At the bottom click the “Open Services
  • In the “Services” window that opens find “Intel (R) Graphics Command Center Service”
  • Double click on it
  • In the Window that opens, change the “Startup type” from “Automatic” to “Disabled”
  • Click Apply
  • Close the “Intel(R) Graphics Command Center Service Properties” and the “Services” windows
  • Restart the computer.
Titan should now launch and run correctly.
Thru our testing disabling this service does not seem to have adverse effects.  If you have graphical errors outside of Titan, you may wish to do the same steps but change from “ Disabled” to “Automatic” and restart the computer again , then perform
the fix again next time you need Titan.
A video of this has also been created here: https://youtu.be/wfJUFc2rCCE
Alternative steps provided by Intel (Not Recommended):
Uninstall all the drivers, as they are only generic and might not be compatible with the laptop.
Our Intel drivers are only generic, we provide our drivers to the laptop manufacturers and they modify them in order to work with their laptops.
The laptop manufacturers integrated the graphic processor and soldered it down to their motherboard, the laptop manufacturer assures the compatibility and the drivers.
We strongly suggest to install only the drivers from the laptop manufacturer
installing incompatible drivers can create some registry issues. the following troubleshooting steps should be applied:
Check that the OS isupdate to the latest version
1. Download the latest graphic driver from the laptop manufacturer website for that specific model of laptop and save it on the computer.
2. Disconnect from the Internet so no new drivers are automatically installed by Windows Update.
3. Uninstall the graphic driver and all the other legacy drivers from Control Panel > Programs and Features.
4. Restart the computer.
5. Confirm in Device Manager > Video Adapters the controller is listed as 'Microsoft Basic Display Adapter' > if not, repeat steps 2 through 4.
6. If the adapter continues to be listed as ‘Intel HD Graphics’ or similar, and no other Intel Graphics driver is listed under 'Programs and Features' for removal, then it means Windows has switched to a previously installed Legacy driver. At this
point we can remove Legacy drivers from Device Manager:
6.1.1 Right-click on 'Intel HD Graphics' or similar, and select 'Uninstall Device'
6.1.2 In the pop-up window make sure 'Delete the driver software for this device' is checked.
6.1.3 Click on 'Uninstall'.
6.1.4 Restart. (Repeat steps 6.1.1 through 6.1.4 until the device gets listed as 'Microsoft Basic Display Adapter')
7. Install the graphic driver that was downloaded on step 1.
8. Restart the computer.
9. Reconnect to the Internet.
10. Download the Intel Graphics Command Centre from the Microsoft Store. ‘
Titan: Grey Pulsing Screen
Alienware Command Center (AWCC) can prevent Titan from running correctly, this may affect users of Dell Alienware machines. Troubleshooting steps for this are currently unavailable and we would advise using an alternative machine.
Tested on Windows 10. Please ensure that all applicable updates have been installed. Windows XP, Windows Vista, Windows 7, Windows 8, Windows 8.1, Bootcamp and virtual machines, e.g. VMware, Parallels are not supported.
In some cases, Titan may launch and present a continuous grey pulsing screen which is related to any one of the following:
Titan.exe application does not launch when starting Simulator, Titan One, Titan Go or Mobile. Two icons must be present on the taskbar. If this is not the case, then you will need to check the following:
Anti-virus and Firewall software (including Windows Defender) may block Titan from working properly on your machine. You will need to check the Titan.exe application exists in the following directory: C:\Program Files (x86)\Avolites\Titan (both Titan.exe and Titan.exe.config must be present).
You will also need to check none of the Avolites applications and services are being blocked by a Firewall.
If the above does not resolve the issue, then it is highly likely another application is using the ports Titan require. If your machine has Intel Graphics Command Center installed, then you will need to apply the following: https://www.avolites.com/support/titan-troubleshooting#2628295-intel-oneappigccwinservice-prevents-titan-from-starting
· V12.0 and above: AvoKey license has not been applied correctly. Please ensure you are importing the correct token file. If the incorrect token file has been imported the engine will start, however, the screen will continue to pulse grey.
V12.0 and above requires a new license request to be submitted via www.avolites.com/licensing. The following video will guide you through the process: https://www.youtube.com/watch?v=86PcC0OzL7E&t=33s
· V12.0 and above: Hardware and application mismatch (e.g. Using Editor Key to launch Mobile Application).
Additional Infomation:
Editor Keys will only Launch the Simulator or GO application (can be used with T1-00001 to T1-019999).
AvoKeys hardware locked to the Mobile will only launch the Simulator or Mobile application.
Need help? please visit https://www.avolites.com/software/help-desk and submit a ticket.
WebAPI Service Fails to Start
If you are having trouble connecting via WebAPI and you have tried all the normal network configuration steps please follow these steps to ascertain if there is an issue starting the USB Expert Service.
- on the console you are trying to connect to go to Tools | Control Panel | More and then select Administrator | Services.
- find the correct version of WebAPI in the services list, if the service is listed as not started click start.
- you should find the service starts and is listed as running, if it wont start then try the following steps to fix the issue.
FIX:
- open Explorer from the Tools menu and navigate to "c:\Windows\SysWOW64\config\systemprofile\AppData\Local\Avolites\WebApiService", please note you may need to show hidden files from Folder Options to see this file.
- delete all folders that contain WebAPI
- now try to restart the service either from the Service manager or by clicking "Restart Software" from tools menu.
How to collect Titan and System Logs (PC & Console)
Sometimes, when troubleshooting complex issues with the Titan software and Avolites hardware, it's necessary for us to get some additional information to troubleshoot the issue further and prevent it from happening again in the future.
To help us get to the root cause of the issue, please send a copy of your Avolites Logs. To generate these logs, please follow the steps listed below:
PC Suite
1.      Open “Log Collector” by clicking the “Start” button then “Avolites
2.      Click the “Go” button and choose the desired save location (e.g. Desktop)
3.      Click the “Ok” Button
You're done! Please attach the compressed file to your email or case with us so that we can assist further. If the file size exceeds 20MB, please use a file transfer service of your choice and attach the link to your email or case.
Consoles
For this task you will need a USB drive.
1.      Open “Log Collector” by clicking the “Tools” button then “Additional Programs
2.      Click the “Go” button and change the save location to the USB drive
The applications below may prevent Titan from starting correctly. Please Terminate before Proceeding...
If you have received the following message after launching Titan, you will need to close the application using the port which Titan requires.
To close the application listed in the 'Network Ports' dialogue box, you will need to open Task Manager, locate the application or service and stop this. When you have stopped this, click 'OK' to retry.
If OneApp.IGCC.WinService, appears in the dialogue box, follow the instructions listed below:
  • Click Apply
Network Ports used by Titan
Titan uses the following ports over the network. If your network includes firewalls you might need to know these so you can set up rules for them.
 Protocol   Port Address Notes
TitanNet  TCP 808
 All available adapters
Titan Remote, TNPs, multi-user and backup
 HTTP TCP 4430 All available adapters
 Web API
 SLP  UDP 427  Multicast 239.255.255.253  Used to discover TitanNet devices on the network
 Ping ICMP echo  Any adapters that are in use  Monitors connection to TitanNet devices
Art-Net  UDP 6454  By default all wired adapters
 sACN  UDP 5568  Multicast 239.255.0.0-239.255.249.255
 CITP  UDP 4809/TCP  Multicast 224.0.0.180  Used for communication with Capture Visualiser and media servers. Discovery done by multicast UDP then negotiates TCP connection
 RDMNet  UDP 5569
 ProDJ Tap UDP 60000-60002, 65023-65535
  Protocol for getting data from Pioneer DJ equipment by software now known as TC-Supply
 LiveDMX  UDP 5584  Multicast 239.184.0.0-239.184.249.255 Used for internal Visualiser DMX data
 NTP  UDP 1234  Between TitanNet hosts  Non-standard NTP port
 NDI  UDP 5353
Multicast between NDI sources and Panel  mDNS for NDI source discovery
 NDI  UDP 49152-65535  Between NDI sources and the Panel  NDI video streams
ICMP echo
ICMP echo
UDP 5353
